Steerfromdarear
- Oct 7, 2017
I'm have trouble finding a 2mm head gasket standard type or mls they seem to be a long wait on the places I've contacted.
You don't want a 2mm head gasket.
I contacted Cometic last week and they said the current wait time is 5 business days.
Listen to Culberro.
I’m curious to know why the op is interested in a 2 mm or .078” head gasket?
The block and head were in bad shape and need to be faced is need the 2mm to retain standard compressionYou don't want a 2mm head gasket.
Where did you contact exactly thanksI contacted Cometic last week and they said the current wait time is 5 business days.
Listen to Culberro.
Decked block and head the engine was in bad shapeI’m curious to know why the op is interested in a 2 mm or .078” head gasket?
how far do the pistons poke out of the deck?Decked block and head the engine was in bad shape
.254 was removed from the blockhow far do the pistons poke out of the deck?
.010"? With pistons poking anywhere from 0 to .007" I'd run the stock gasket, I'd love to have that kind of squish..254 was removed from the block
Carrier pigeonWhere did you contact exactly thanks
I have a 1.8mm gasket would this work? in total with the with the amount off block and head I need 1.94 gasket be standard compression.010"? With pistons poking anywhere from 0 to .007" I'd run the stock gasket, I'd love to have that kind of squish.
Carrier pigeon
No, the chat window on the Cometic website.
The amount that was removed doesn’t really matter. The amount that the pistons are above the deck is what matters..254 was removed from the block
If the pistons are .254 above the deck if you fitted 1.2 standard hg + .254 =1.454 would leave standard head to piston clearance how would this leave the valves and compressionThe amount that was removed doesn’t really matter. The amount that the pistons are above the deck is what matters.
My advice, measure the piston>deck heights to be sure, then aim for a piston to head clearance of 0.035 (+0.0025) inches.
Is this a turbo motor?The block and head were in bad shape and need to be faced is need the 2mm to retain standard compression
Turbo motor I checked it before I over heated the engine to leave it back to standard I used a 1.5mm head gasket It was skimed again .4 so I need a 1.9mm gasketIs this a turbo motor?
How much was removed from the head? I see that the block had 0.25mm removed.
Ok, so 0.4mm off the head is just about getting into the good place for a turbo motor, see below.Turbo motor I checked it before I over heated the engine to leave it back to standard I used a 1.5mm head gasket It was skimed again .4 so I need a 1.9mm gasket
The head was skimmed twiceOk, so 0.4mm off the head is just about getting into the good place for a turbo motor, see below.
You have only removed about 2cc of volume from the chamber, so the head around 49.5 CCs (~4.5cc/mm of head being machined).
Your final CR with turbo pistons and a stock thickness HG is 9.1:1 CR, which is a great spot to be in.
If you're using naturally aspirated pistons the CR would be 10.3:1, which means you'd probably want to open the head a bit by unshrouding the exhaust to gain some chamber volume. Or run it at the higher CR and possible have some detonation unless you lower boost or alter the timing.
If the engine has turbo pistons, I'd run it as is with a stock HG. It would be a really good place to start.
