So what was the total amount off the head???T
The head was skimmed twice
I would cc the chambers just to be sure.T
You will be fine with those numbers and a stock head gasket..09 + .4 = .49 was removed total of head
.254 was removed from the block
Perhaps I am confused, but units? Are those in mm?.09 + .4 = .49 was removed total of head
It's mm. No one it taking a 1/4 inch off of the block.Perhaps I am confused, but units? Are those in mm?
I read that and was wondering. I wanted to make sure.It's mm. No one it taking a 1/4 inch off of the block.
That's called a shortblockIt's mm. No one it taking a 1/4 inch off of the block.
I checked the piston is .60mm above the block I have a 1.8 mm gasket could I fit thisYou will be fine with those numbers and a stock head gasket.
That is a lot more than 0.254mm...I checked the piston is .60mm above the block I have a 1.8 mm gasket could I fit this
Are you converting these units from inches, or is the metric system your measurement system?
With the pistons sticking out that high, you'd want something like a 1.5mm head gasket for a good squish distance of .035in(0.89mm). The 1.8mm head gasket would work though, and that would be at about where the factory squish ends up.
With your measurements changing so much, I'd recommend REALLY knowing what the values are before making decisions.
What about the valve clearanceYou have an effective piston to head clearance of 1.2mm. You should be fine.
effective valve clearance at .3mm, but due to cam timing you'd only get that close if you broke a belt with exhaust fully open.What about the valve clearance
My V16T cam is interference, when I was setting up the timing belt, I had to turn the crank backwards after a piston was stopped by a valve. It's had the head cut a couple times and the block decked. That was with a stock head gasket.There's no chance a valve in an 8V redblock is ever going to hit the piston short or a timing failure. The intake and/or exhaust valve would have to be open 10mm or more while the piston is going from the exhaust stroke to intake stroke, which is insane.
But with what numbers? The measurements he posted are in clearance. Done. If they’re correct anyway.My V16T cam is interference, when I was setting up the timing belt, I had to turn the crank backwards after a piston was stopped by a valve. It's had the head cut a couple times and the block decked. That was with a stock head gasket.
