doggydoggen
- Dec 13, 2024
yes you cant compare injection with carburators, but fiddling with engines, building stuff is a part of the joy, i have for example a ferrari with 4x 42dceo weber and it works very well, and when you learned how to tune them it is not so difficult, but if you want tune and forget, webers are not for you.Coils on plugs is very easy and utterly reliable.
50mm IDA-3 look-alike throttle bodies can be had with internal injectors. Carburetors are such a pain compared with modern management. Programmable management will run exactly the way it is programmed to.
Where you can; let the bent six really yell! Just be sure you are OK with bearing speeds.
