TurboDutch
- Aug 5, 2019
- Nieuw en Sint Joosland
I just held the top of the carb up and move the float up to closed position. When released the needle on the inlet valve would stay up. Then vibration or a bit of a tap and it would fall. It also didn't slide smoothly from an open to closed position. Just not a good inlet valve. Even a good stock replacement would have worked better. The Grose Jets were cool because they make the whole valve movement based on a couple of ball bearings so it is smooth operation. I see IPD sells them and so do the British car parts venders. Wasn't a performance increase or anything. Just reliable operation.Thanks mate, how did you find out?
Dang, those dish pistons are killing the CR.35cc abt close to 1 tot 12 ratio.
I have 25cc dish, 96.4 bore 101 stroke.
Pistons above the deck 0.2
Using elring gasket
