so, I've read a couple posts on other sites about the 850 302mm upgrade
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=38299
and the poi pointing out that 960=850 brakes
http://forums.turbobricks.com/showthread.php?t=85788
This thread actually shows the bracket style the 960 has that someone got by mistake, even though the mount on the spindle is the same, the brackets and calipers are different, and apparently both the part numbers talked about in the thread are for the 850, its just new vs reman and the coating, but a lot of people get the wrong brackets in the box, even though that photo shows a 8251319 box, those are single piston caliper brackets not the 8251319.
http://www.matthewsvolvosite.com/forums/viewtopic.php?f=1&t=46093
I know I can change over to the 2 piston 850 calipers when I do the swap and just use the apparently easier to find 850 302mm caliper brackets, but does anyone know of bracket that will just move out the stock 960 caliper the way the 850 bracket does so that all I have to do is swap the bracket and rotor and keep the caliper the same?
