juss
- Sep 3, 2018
- Estonia, Tallinn
Last time I checked you can get the same sealant from ford (aka old step dad for Volvo) for much cheaper
Maybe, have not looked into it so would not know. Friend is actually in a dealership where both Volvo and Ford are represented, I would think that he would have suggested it if it was cheaper. But I can't complain, got the Volvo lettered one for a really good price.
Noted, if I can find it and it has a smaller cost I might give it a try with the next engine. But I did found Ajusa brand stuff for a decent price and with a couple day lead time. Cannot say if it is any good. Product code for the Ajusa one for reference - 75000400I've been using Permatex flange sealant for the last 15 years or so with no issues.
Got some packages what I was waiting for. The clutch came, 707 pressure plate and Tenaci 10x35 spline organic sprung clutch disc. I hope it is a bit better for daily driving. Also some connectors for the wiring loom, T5 specific. Coolant, crank and cam signal, etc.
Friday did not have not much time, so did a couple of welds on the oil pan. Starting to like what I am seeing, there is loads to learn but taking into the fact that the flange is seeped through with oil and cannot be completely clean in the end I cannot be mad about that.
But going on. We had our independence day yesterday and I put it to good use, as it is a free day of work.
Installed the shims, head gasket and got the head all torqued down. Went without hiccups, but had to get a new tool. Angle gauge for 1/2 breaker bar for the last 130 degree torque.
Not an MLS gasket, for cheapness and this engine will not be high hp, so no need. I hope.
Most of yesterday I compiled the water pipe underneath the exhaust manifold. The bend part from the water pump was actually done in sections months ago just to practice TIG welding and it shows. But relocated the overflow port, added turbo coolant feed/drain and the cabin heater port to the rear of the head. Should be room for everything.
Have to leak test it somehow before, don't want to put coolant into it and discover it leaks, as it is a pain to weld after that. Have done that before...
But those who have done the T5 swap, what did you do with the ports for the oil cooler which is near the water pump in the block, PCV coolant ports in the back of the head, thermostat housing and under the inlet manifold? The inlet manifold one is for PCV vaccum? Sorry stupid questions but at times I get confused.
Until next time.
