740 Non-ABS pulling when braking
NLRegina
Hi guys, I've got a problem that seems like it should be simple, but I haven't been able to resolve. On my 1991 740 with a Non-ABS dual/triangular circuit braking system, the car pulls to either the right or left on medium braking sometimes. It's most noticeble occasionally in traffic, when I coast up and let off the brakes, and I have to fight the steering wheel a bit.
Now I know what the usual suspects are, stuck slider pins, seized pistons, brake hose internal failure, etc. However, I have almost all new braking components all around. New pads, rotors, hoses, and calipers front and rear (technically the rear calipers and hoses were done a year earlier, so not quite as new)
The system was pressure bled at about 30psi in the specified order, Rear left then right, Front right then left, with the upper screws bled first on the front calipers. I bled it multiple times when I first did everything until I wasn't getting any air bubbles.
One item of note during the bleeding, I noticed my pressure bleeding wasn't holding pressure. It would go down a little bit after a few minutes. I could not see any fluid leakage anywhere after waiting some time, or hear anything to indicate that pressure was being lost. I assumed at the time that the pressure bleeder itself was not sealing up properly somewhere, since I saw no other evidence of leaks.
I did experience a bleeder screw sealing failure on the front left caliper the first time, and had to replace it a month later after I found it leaking fluid from the top screw. I replaced the caliper, and the pads seemed fine and were basically new ceramic pads so I left them....
Now, a year or so later, and I have the diving symptoms as described. Looking at the front end, the slide pins are all still nicely greased and slide freely. There is a slight lip forming on the passenger side rotor that is not present on the drivers side.
Additionally, at some point I installed the IPD strut rod upgrades, which have different bushings with cavities in them compared to the stock style solid rubber block bushings. Maybe I installed these upside down? I noted that the strut rods seemed to point upwards slightly when the suspension is weighed down, so I tried to angle the rods so the cavities in the bushings were perpendicular to this angle.
All that said, what am I missing here? Right now I see a handful of potential causes:
Fouled drivers side pads. The drivers side rotor lacking a lip compared to the passenger side might be a result of brake fluid leaking onto the pads and fouling them, so I don't have as much braking power on the left.
Air in the system. Maybe I messed something up with the bleeding and there are air bubbles which are giving me uneven braking pressure.
Faulty master cylinder. Maybe my brake system not holding pressure is actually a result of a faulty master cylinder that is leaking into the booster? However the brake fluid level does not seem to have meaningfully decreased over rhe past year. My pedal feels firm and does not seem to be weak. I wonder though if a 35 year old MC is having internal issues that are leading to uneven braking pressure.
All in all, I would like to get this sorted out so that I can feel more confident in my brakes. Does any part of what I described above stick out as a mistake? What would you do in my situation? (other than taking it to a mechanic)
Interesting problem. You seem to have done everything right with the brakes. I was grasping at all kinds of possible straws in my mind until a light bulb went on:
Badly worn control arm (radius rod) bushings! That can cause all kinds of inconsistent braking and vibrating brake issues. It's most commonly the front cone bushings. When was the last time they were replaced? If recently replaced then there are updated and original style cone bushings, so could be a problem if they're mismatched and prematurely wearing.
If the front cone bushings are recent then consider that the control arm pressed in rear bushings may be gone, which means replacing the whole control arm. To check the rear bushings it's best to remove the control arm and solidly clamp the rear bushing in a vise then try lifting/lowering the rod to see if the rubber is starting to tear. If you do replace a control arm, be sure to carefully match the control arm length as different control rods were used and made available dending on year and wheel diameter (14", 15" and 16"), with an "updated" control rod being issued for the 15" wheels that uses an "updated" front bushing. With effort, the reference lengths can be found online to determine which ones you currently have.
If it is pulling either to left or right, rather unpredictably, then it must be something with the geometry. With the pocketed bushing, i can imagine in normal resting state the rod is 'pulled' further away from the chassis, partially collapsing one pocket. When braking, the rod is pushed, and the other pocket is being collapsed, depending on braking force.
I do not get though why they suggest to install rod end bushings like that. Rod can mostly transfer longitudinal forces, so assymetries/rotation in mounting the bushing will mostly just make its stiffness different, when pushing/pulling the rod.
I have no issues with the stiffest (by design, not by shore) possible Lemforder cone bushings and solid rubber at the end of the rod, been in the car since 4 years without trouble.
Also I'd suggest taking it to measure braking forces/roller test bench. With the triangular circuit, if brake mechanics are sound, circuit pressure difference can mostly be seen at the rear wheels.
Badly worn control arm (radius rod) bushings! Thay can cause all kinds of inconsistent braking and vibrating brake issues. It's most commonly the front cone bushings. When was the last time they were replaced? If recently replaced then there are updated and original style cone bushings, so could be a problem if they're mismatched and prematurely wearing.
Good thought with the radius rod bushings. These are entirely new, I used this 388.5mm rod kit from IPD here: https://www.ipdusa.com/products/215...T_AR2Cniv4EAQYAyABEgK_a_D_BwE#image-gallery-1
Along with new Lemforder 6819057 rubber cone bushings. I did notice that the pocketed bushings were not installed perfectly identical between the two rods I got, and I contacted IPD support, they told me the different was minimal and shouldn't cause any issues.
For what it's worth, I did not consider the wheel size when I instaled the new rods. I've been running a few different sets of 15 and 16 inch wheels, and the results have been the same. The issue was definitely noticeable on both diamters of wheel.
I did not stop there either, I also installed new TRW control arm bushings on a used set of aluminum control arms that I refurbished. For what it's worth, my suspension feels great, it glides over bumps effortlessly without feeling loose.
I'm tempted to try flipping the strut rods around to see if that improves things.
What kind of shop would offer to measure brakijg forces? I'll admit I'm not too keen on going to a professional, but I'll keep that option in my pocket.
Right now I think I'm going to try and keep things simple and start with the basics - some cheapo front pads from rockauto and another round of bleeding all around to see if anything changes.
It sounds like your car is not aligned correctly. I'm betting the front end is aligned with toe out vs. toe in the way it is supposed to be. That would be the only reason for it to pull in either direction under braking other that loose parts. It happens more often than you might imagine. Techs that don't understand what they are doing and why.
I'll pull up the last alignment spec sheet later this week and check it out. Wouldn't put it past the shop to have it done wrong. In any case, I made it down Mt. Washington without diving off a cliff, so things are holding together ok for the time being.
are the wheels an odd offset?
And what are your camber/caster measurements?
Neg offset, high caster, excess neg camber, excess toe in will make it more darty. Add a bit of each and it will be unpredictable
They're just Hydras, only thing that isn't stock is the IPD spacers in the rear. Can't speak on the alignment specs though, I'll get a pic of that later this week when I dig up the sheet
If it is just the wheel shifting (excess steering play) i would check all that.
If it consistently pulled one way i would back up and see which way the steering moves under braking. If the wheel turns opposite compared to forward braking, it’s a brake issue. If it turns the same direction forward and reverse, it is a loose bushing changing the caster.
This one is tricky without driving it myself.
It doesn't feel like the wheel shifting - whole front end is new and tight. The front rotors do tell a story of the right side doing more work, there is a lip on the right that is not there on the left. Most of the time it does feel like a pull to the right when it does happen.
Essentially on medium level braking it pulls to the right sometimes and sometimes the left too, and what's most noticeable is every now and then when I let off a little to coast up, it wants to pull harder to the right, almost as if I'm fighting the right side brakes. It could also be though that the left side is just not braking as hard and is "letting go" earlier.
Jack up the front end and then apply the brakes hard and release them. Get out of the car and spin each front wheel by hand. If the brakes are sticking you will be able to tell just doing this.
I'll give this a shot later this week, but if that's not the issue, where would you look next? I recall trying something like that before and not seeing anything meaningful.
Also, is there any chance that a failing master cylinder could cause these types of symptoms?
According to those specs your car is toed out. Toe in is a negative sign. Toe out is positive. The camber and castor is fine. They f'd up and aligned your 740 as if it was a FWD Volvo.
The specs below can be found here. https://www.volvoclub.org.uk/faq/FrontSuspension.html
Caster: [Editor] Caster is adjusted by replacing the control arm strut rod. The standard length (distance between the centerline of the rear bushing and the front of the rod) is 390.5mm; the shorter version which reduces caster angle by 0.8 degrees is 385.0 mm and the longer which increases caster angle by 0.8 degrees is 396.0 mm.
Toe is adjusted by rotating the inner tie rod within the outer tie rod end to pull or deflect the wheel in the desired direction.
Specifications. Wheel alignment angles for 740/760/780/940 cars are:
Angles15 inch wheel16 inch wheel
Caster5° +/- 1°4.5° +/- 1°
Camber0.1° +/- 1°0.1° +/- 1°
Toe-In AngleToe-in angle: 18' +/- 8'Toe-in angle: 18' +/- 8'
Toe-In Distance*2.2mm +/- 1.02.3mm +/- 1.0
* when measured from left to right from rim center to rim center, front and rear of wheel
Got it, so I guess I need to get it redone and make it clear I want toe in. Maybe they assumed it was a racecar.
One thing that just occurred to me and may explain some of the squirrely behavior - last time it was aligned I had my roof box on top on the passenger side, with my bag of tools and other stuff in there. I removed the box in the winter and just stashed the tools in the back on the passenger side to try and keep the weight distributed evenly. But since it was aligned with the roof box I probably threw things off a bit when it was removed.
lol Had you told them you wanted the car to rotate quicker, that would be legit. I run slight toe out on my Mustang GT. It makes the car a hand full with rutted pavement. I don't dare take my eyes off the road for more than a split second.
