apachechef
Burnt Sierra Madre
- Jan 26, 2009
- An obscure body in the SK system
I had hard hot start problems that ended up being those little orings.Did you change the oring in the distributor that controls your system pressure/ return? Those can also create starting issues as fuel is just returning to your tank. Check that kjet.biz site. The dude in Australia has a ton of those oring kits for the 3 different control plunger styles.
overall sounds like vapor lock type issue, exacerbated now that you have a hotter engine bay. I think using non ethanol gas will help a little, but you need to check kjet pressures.
If you haven't replaced those orings on that needle assembly, its a cheap place to start, and should be done anyway.
