SOLVED: see 4th post
Overview:
-Brain Hurting
-Fuel Yes
-Spark Yes
-I have Timing Questions
-I have Vacuum Questions
Timing
This is where my distributor ends up when at TDC with cam pulley/crank sprocket notches lining up and the crank pulley notch at 0 on the cover. Should the rotor be centered on the tiny notch next to the hall sensor? Timing light on #1 during cranking indicates ~12degrees. I'm very confused but think maybe the timing has fallen off by ~5 degrees mysteriously since I last set it. The belts got a tightening recently, if too tight, could this have messed with the harmonic balancer? I had the cam out to do hushers and shims recently, and failed to line up the intermediate gear, ended up pulling the diz and rotating it on the teeth, is this a no-no?
I got it running yesterday by resetting the timing...and burning off the plugs...but it's back to no start today
During the running, when it's warm I can shut it off and restart. It has had a hard cold start for the last 2 months until this no start issue. The hard cold start is very rough 2 or 3 cyl firing for 20 seconds then it would run ok but with a hunting idle. Vacuum is steady at 10in, from what I've read indicates a possible timing or vacuum issue, maybe I have both (but wait there's more below). While engine running yesterday, I was searching for a vacuum leak (using propane) couldn't find any until I decided to pump the brakes and suddenly the RPM shot up. This was repeatable, but a problem I didn't have before or maybe I just missed it. The brake vac check valve is new. I didn't hear the hissing that others have heard from a blown booster (could it be so bad you wouldn't hear that?), strangely the brakes seem to operate normally as far as I can tell not driving it, but may have to hook up vac to do the proper test, or just go ahead and replace it. Clearly the brake booster is introducing air into the manifold, no? Is there anything else pumping the brakes could be activating?
I also have another thread open where I found that the tank pump doesn't run when cranking, which has been addressed by others on that thread, but requires more investigation.
To add insult to injury, I snapped a hood hinge last week. It was wonderfully simple to diagnose
Growing weary eyed
Any input much appreciated
Tack själv!
Overview:
-Brain Hurting
-Fuel Yes
-Spark Yes
Timing
Growing weary eyed
Tack själv!
