I found a troubleshooting blog for a 2.3L engine from an 850. Someone provided a complete test sequence for the gent..... wiring and connector testing essentially identical to my REX green book data. However this test sequence also included actual measurements of the signal. I will check if the 850 uses a Bosch sensor like these tractor engines. I know most 850s are Mo_Tronic ECU so likely the monitoring is different that what VOLVO Engineers spec'd for these 8V iron engines. Nice article, thanks for adding this to my thread!So you refuse to check the signal?
It would make sense to me to confirm if it is putting out a high signal, low signal, or no signal. The code is very vague.
Bob, if I used one of the cheap O-scopes, would I connect across the pair of pins at the REX ECU to obtain a waveform? How about a data log trial, highway run? Do I need special hook connectors on the scope so not to damage the connectors? Wait a minute, there is also an inline connection under the hood at LH strut brace, perhaps I could reach these connections for a driving trial? I have not used a scope in, oh, about 45 years (Physics lab) so I'm going to need some assistance on this one.IDK, there's not much info available about Rex knock issues
Several articles claim the spark knock is symptomatic of LEAN conditions in the combustion chamber...... and my vacuum signal is still nearly 14 inches HG. It is plausible that my undetermined vacuum leak (perhaps leaking intake gasket which I reused) is sneaking fugitive air into one of the runners and these phantom knock signals are being caused by that?
I'll post a separate thread question about used intake gaskets & vacuum leaks thereby.
