haroldburbank
- Jul 6, 2024
have 92 240 wagon. recently tail, brake and dash lights failed at once. suspect bulb failure sensor, which was replaced a year ago when that harness showed melting and low beam headlights failed. now no power to tail lights (volt meter tested). curiously brake light circuit shows power but lights wont come on. all fuses checked and good. good power to relevant fuses (volt meter). tested bulb failure sensor harness. no power when tail light switch off. power to 'lamp failure' female node with lamp switch on. curiously the harness ground wire node has power with tail light switch on (sensor removed from harness). there must be a short, possibly in the cargo door hinge harness. the current bulb failure sensor appears fine. no change when i installed a spare. theory 1: slightly melted bulb failure sensor harness has a short. never found why it melted, it has worked since melting without obvious defect. theory 2: cargo door hinge harness shorted. did not check yet. i see no direct connection from this harness to the tail lights. can a short in the hinge harness feed back to the tail lights via the brake light system? the hinge harness serves the rear window brake light which of course ties in to the entire brake light system. comments? thank you.
