ZVOLV
<Master Tech>
- Nov 19, 2002
- West Texas
Once a battery has been discharged too many times, you aren't going to be able to bring it back.
Your Volvo runs off the alternator, not the battery. Check your charging system.I guess it might help if the battery in the car was actually rated for it yeah? Keep reading that 600-750 CCA is what the car should be using. Checked the current battery and it is rated at 525. Going to get bigger battery and install, should make everything happy.
No. You may just get a high idle after a freeway run.Got it up and running again, but now getting a 3-1-1 code. I know the speedometer doesn't work, but could that be giving me a bad time under load?
Got home, tried to start it and fired right up. Was hesitant with gas at first but after idling for a little bit it cleared up and was able to move around. Last time it was just the oil change after the resistor pack. No clue as to what happened with it this time, but I am still going to get a bigger cca battery just to be safe.No. You may just get a high idle after a freeway run.
WTF did you do to get it running the last time and this time? I don't see where you posted that you did any repair. It fixed itself?
Just throwing this out there, but I resolved a persistent cold rough idle/misfire on my car after 2 years when I replaced the battery as well as the ground straps on the back of the engine. The battery was very low in the cold morning to the point of getting phantom electrical issues in the gauge cluster/seat belt chime for a few seconds and cranking slowly for just long enough to start. The ground straps on the back of the head were in awful condition, almost completely frayed away at the valve cover connection. I think these grounds are commonly ignored and I suspect I was getting injector/fuel mixture issues as a result. I would recommend checking those straps out. If they're original, the movement of the engine over time has probably worn them down significantly.Got home, tried to start it and fired right up. Was hesitant with gas at first but after idling for a little bit it cleared up and was able to move around. Last time it was just the oil change after the resistor pack. No clue as to what happened with it this time, but I am still going to get a bigger cca battery just to be safe.
Talking the braided ground wire to the back of the head? Recently checked and looked good at head, but I will look further in and see if anything is cut up. I know when I bought the car, it looked like the strap had been replaced, but that doesn't mean much from where I bought it.Just throwing this out there, but I resolved a persistent cold rough idle/misfire on my car after 2 years when I replaced the battery as well as the ground straps on the back of the engine. The battery was very low in the cold morning to the point of getting phantom electrical issues in the gauge cluster/seat belt chime for a few seconds and cranking slowly for just long enough to start. The ground straps on the back of the head were in awful condition, almost completely frayed away at the valve cover connection. I think these grounds are commonly ignored and I suspect I was getting injector/fuel mixture issues as a result. I would recommend checking those straps out. If they're original, the movement of the engine over time has probably worn them down significantly.
It took awhile to figure out because the issue went away with a little bit of throttle and it was fine to drive, so I had a hard time diagnosing components
Yes, should be 2 of them going to each side of the valve coverTalking the braided ground wire to the back of the head? Recently checked and looked good at head, but I will look further in and see if anything is cut up. I know when I bought the car, it looked like the strap had been replaced, but that doesn't mean much from where I bought it.
While running, but in tank was recently replaced, and in line is only 1 year old.Just skimmed, was the fuel pressure tested while running or when it was running bad? Bad main pumps have been the most common intermediate running issues under load for me.
Yes current list of replaced or refurbished parts is as followsSave me reading back through 8 pages. Has the CPS ever been replaced?
