- May 27, 2008
- Ithaca, NY
Waiting on handbrake parts and one rear caliper. I had freed both rears, however I noticed in pulling the calipers that both had torn inner boots. I can probably source boots, but since they were stuck anyway, I'm just going to replace both rear calipers. In the meantime, I pulled the seats & started on the upholstery replacement & foam repair
edge molding to hopefully slow down the foam damage moving forward
Reinforced backing to keep the foam together.
new seat heater grids
upper
seat pad upholstery - really good fit. Couple hog rings in the middle
Also treated her to an upgraded fusebox using ATC fuses instead of the old bullet style from Wagonmeister. Wasn't cheap, however it's really well made. Had 3 extra positions added beyond the stock 16 fuses
fuses face straight back, so easier to access than the original diagonally set design
upper
