Haha 10-4 buddy I've got a pretty good imagination.Dude I'll have to look. I can tell you that if you imagine a '93 244 with a factory-installed B230FT, it looks like that.
92 940. The base needed a bunch of modification, but we wanted to keep it.it looks like you used a complete 7 series air cleaner. I just have the top part with just the bottom flange holding the filter. I need to revisit why I went that direction.
Excellent
I would like to replicate this. Perhaps with a battery relocation and a electric power steering pump.
Very nicely executed. It looks factory, other than the IC hose/pipe clamps.
Thanks! 100% what we were going for. The 16T I got from you maybe a year ago or so is for this car.Very nicely executed. It looks factory, other than the IC hose/pipe clamps.
So it's a do88 ic for a 940 I assume? With the lower enter and exit?This car also has a do88 intercooler, just to point out that you're not limited to the factory stuff. Really, that's just a testament to how well the do88 is made.
You are running a 240 radiator correct?This car also has a do88 intercooler, just to point out that you're not limited to the factory stuff. Really, that's just a testament to how well the do88 is made.
Correct. 940 w/AC.So it's a do88 ic for a 940 I assume? With the lower enter and exit?
Yes.You are running a 240 radiator correct?
10-4 thank youYes.
There is room in the rear butt cheek for the battery and the washer fluid container together. You can just reuse the existing tubing that goes to the rear window.So far I have the engine in and I'm getting closer to having the 940 ic mounted. Ive never had a Volvo with working AC so for now I removed those components. I wish I could use the 940 air box but I have to choose what I'd rather have. Washer fluid, or air box. I've got a little time to decide because the trans is torn apart at the service shop. Everything has been quite manageable so far. I installed a big tank pump and deleted the main pump as well.
My god that's a great idea. I have a battery that can fit sideways in the battery tray but I already have materials to move it to the trunk so I might just go ahead and do that. I already need to troubleshoot the rear window washer nozzle not moving fluid too.There is room in the rear butt cheek for the battery and the washer fluid container together. You can just reuse the existing tubing that goes to the rear window.
Tim
