rstarkie
- Jan 23, 2004
- Hamilton, Ohio
I am not getting 12v to fuse #15 (yellow wire) at the fuse block.
I am under the impression that the intermittent wiper relay is only involved when the switch is moved to the intermittent position. I did recently have the fuse block out to bypass the fuse for the blower motor so the wiper failure might be associated with that, but the wires on the underside of fuse 15 are in place.
Does the yellow wire that supplies fuse 15 come directly from the ignition switch and if so does this failure indicate that the ignition switch is the source of the problem?
