Thanks for the reply. No, the lpt wastegate is fixed rod lenght. I think the default pressure of the lpt is between 4 and 5. I'm not even making 2Start by checking the wastegate preload. If it has an adjustable rod on the wastegate you can tighten that up a bit. However, the LPT is only supposed to make about 3psi or so. You could change the wastegate actuator to an FT version or other pressure ratings if you shop around like at ATP Turbo or ebay.
I know what you mean. A faulty puck could be the culprit. I have already disassembled the bypass valve and the membrane looks brand new. The wastegate is not stuck, since I could move it by hand. And the membrane of the wastegate is certainly not torn, otherwise I would have the opposite issue.One of the things that can happen is the puck inside the turbo can break or crack letting exhaust past and not making boost. Also a clogged catalytic converter will prevent boost. You can test the exhaust back pressure before the converter. There is usually a test port in the front pipe. It should only have about 1.5psi back pressure.
Measuring manifold boost pressure by tapping into an unrelated vacuum line?I installed the gauge into the cruise control vacuum line.
I have checked for cracks from the outside and I haven't find any. Offcourse doesn't mean they aren't there. Although I don't have common signs like black smoke marks.2 physical defects are typical on high mileage B230FK:
- big cracks in the hot side of the Mitsubishi td04-13C turbo. Waste gate side. It means the WG valve is never fully closed which is needed to start making boost. This never sets a check engine light because at no point exhaust gas is leaking from the exhaust.
No idea if it is fixable. You need to closely inspect the hotside which requires the turbo to be removed.
- cracks on the underside of the exhaust manifold. Those cracks leak exhaust gasses away that are needed to spool up the turbo. This might set a check engine light.
Those cracks can be fixed by hard-soldering.
- the tdo4-13C is also known for the CBV membrane (under the chrome 3bolt cover) to fail/leak. (it is basically a short circuit on the boost side.)
It may be possibly what's happening to mine. But I don't here any rattle even when I play with the WG arm back and forth. You know, I hear it move, but nothing I would think is out of the ordinary. Also when I release it and the flapper hits the port it doesn't sound weird, it sounds like it makes good connection and sounds the same everytime. But this is very subjective. I need to check inside with the borescope.Checked the calendar... almost 3 years ago, I got to swap out both turbos on a 2007 BMW 335i. The "flapper" shaft holes had worn so much in the casting that the valve/puck was no longer centered or flat on the port. Leaked, rattled, uneven boost (if at all), etc.
