945 slight restoration
santona1937
This is my project. Bought about 4 weeks ago for a not huge sum. 1993 945 2.0 turbo. It had some issues which i and my trusted indie garage have sorted out... front brakes discs and pads, exhaust hangars broken, fluid change, cambelt and asscoated bits. smell of fuel and stalling regualrly when at idle . The stalling at idle was the most annoying, and after replacing the Radio Suppression relay, cleaning the ICV, replacing the fuel pump relay... turns out it was a loose wire.. anyhow there is zero rust underneath or in body work, it has the apparently common odometer stuck issue, needs a new centre bearing and asome work on the steering rack. But it is lovely to drive...
