comanche250
- Jul 12, 2024
- Okanagan, Canada
Would the IPD turbo cam be similar enough to the stock T cam to be worthwhile?
It follows a similar theme but does have more duration and therefore overlap than the T. That said it does have a good increase in lift.Would the IPD turbo cam be similar enough to the stock T cam to be worthwhile?
hmmmmm. If the IPD/Enem cam will give me the same low end performance with a better mid/top end, I would probably go for that. Interference doesn't scare me, this is my first non-interference motor after all, I just keep an eye on the belts.It follows a similar theme but does have more duration and therefore overlap than the T. That said it does have a good increase in lift.
The IPD turbo is essentially a clone of the Enem V15 from Sweden, which comes in both NA and turbo flavors. The only real difference there is the overlap. Less for the turbo, more for the NA.
I assume that since you are going for more power that you don't really care about the engine becoming interference? The nearly 12mm of lift the IPD turbo cam brings to the table will likely make your engine an interference one.
There is though a metallurgy thread about the IPD turbo cam that has folks doubting their quality as of late. Weird wear patterns observed by a few people. If you are shelling out $250 + shipping then it is $100-150 more to just order a V15 from Sweden that won't exhibit weird wear.
Did you ever try running tighter clearances on the t-cam to drop the DCR?I wouldn't shave the head for a T, read up on dynamic compression ratios. 1mm shaved off and a V is similar dynamic compression ratio to a T with a stock head, a T actually raises the compression ratio of the B230F. I'm exploring this right now. 8V are limited when it comes to short duration (torque) cams because the ramp can only be so fast and there aren't any good options between the T and V imo. In the V8 world you can get a cam with the duration of the T but as much lift as the hottest 8V aftermarket cams.
This is a good read for the benefits of reducing the piston to head clearance: https://pbase.com/stealthfti/b230ftshortblock
The valve events thread sticked in perf/mod has a spreadsheet inside that shows dynamic compression calculations. It's a little spotty so I'd double check the work but it's a good reference.
In this video they dyno'd an A cam advanced, along with other "torque" cams
You know I haven't actually checked my valve clearance yet. How big of a difference would that make? I've been out of doing it since I'd have to order shims, and ignorance is bliss.Did you ever try running tighter clearances on the t-cam to drop the DCR?
Quick math shows the DCR to be in an acceptable range for pump gas.
I didn't shim it tighter, I didn't have large enough shims to get under .015". I still have the sheet of the shims I used, I could order them and try again. It ran good at WOT, idle was rough. So much cranking pressure and the weak 240 mounts just made it wobble roughly, kinda hard to explain. It idled as nicely as the V basically is an easy way to put it. I did run premium and it did seem to fix the detonation I got but drivability was still not amazing.Did you ever try running tighter clearances on the t-cam to drop the DCR?
Huh, it really sounds like something is off on your setup. It shouldn't idle rough from just the compression ratio change.I didn't shim it tighter, I didn't have large enough shims to get under .015". I still have the sheet of the shims I used, I could order them and try again. It ran good at WOT, idle was rough. So much cranking pressure and the weak 240 mounts just made it wobble roughly, kinda hard to explain. It idled as nicely as the V basically is an easy way to put it. I did run premium and it did seem to fix the detonation I got but drivability was still not amazing.
Paging @shoestring because they actually did the measurements.You know I haven't actually checked my valve clearance yet. How big of a difference would that make? I've been out of doing it since I'd have to order shims, and ignorance is bliss.
Yeah I'm not sure what it was. I went through everything trying to get some chips to work. Cam gear didn't leave the belt so it wasn't off timing as seen by the performance I got. Flat top B23 should be the same dcr, no idea why mine wasn't super happy.Huh, it really sounds like something is off on your setup. It shouldn't idle rough from just the compression ratio change.
If it's idling rough it really sounds like cam timing might be off. I'd double check and make sure the TDC on the balancer is actually at TDC (I always use a long phillips screw driver or a 3/8 extension for this).Yeah I'm not sure what it was. I went through everything trying to get some chips to work. Cam gear didn't leave the belt so it wasn't off timing as seen by the performance I got. Flat top B23 should be the same dcr, no idea why mine wasn't super happy.
Ignorance leads to worn out cam lobes or burned valves in some cases. You can't just swap cams and not check the follower clearance.You know I haven't actually checked my valve clearance yet. How big of a difference would that make? I've been out of doing it since I'd have to order shims, and ignorance is bliss.
Thanks tipsIgnorance leads to worn out cam lobes or burned valves in some cases. You can't just swap cams and not check the follower clearance.
No to the T, yes to the V15A question here; does the Enem V15 NA make a B230F interference then?
Also, does the T cam make it interference?
Thanks.
Hello yes I'm here. I had to go back and look at the cam page. So on a KL T3 that we recently did, the difference between a 0.010" lash and a 0.015" that we normally use was 13* intake and 14* exhaust. So yeah, a ton. I might imagine that this aftermarket cam might even have faster ramps than a stock camshaft, so with a Volvo cam the difference might be larger than that. My Mike Jones grind asks for 0.011"/0.012".Paging @shoestring because they actually did the measurements.
From what I recall, you can change the duration around 15deg by going to a tighter lash of around 0.008" vs the 0.014-0.016" that most people set their cams at. The valvetrain also gets MUCH quieter with tighter lash, and everything is a lot happier in the valvetrain.
