OVERDRIVE
- Jul 31, 2017
- Brooklyn, Neu York
1990 240: I did a fuel pressure test today. Pressure was correct but took a while to build. I used a fuel pressure tester kit off of the valve on the fuel rail, there were no leaks. The air never bled out of the pressure gauge, there's a video online of someone doing the same thing, and his gauge bled in seconds. While running it seemed to be pretty lazy about finding the correct pressure. The air that never bled out of the system concerned me, so I put a clear vinyl tube on the return, and jumped the pumps. The fuel coming out of the rail was very bubbly. Basically straight froth. I pulled my fuel sender and I can't find any issues. I was low on fuel (not in the red though, I've gone way below the red without running issues). Am I crazy? Even if the sock stuck up above the fuel line, the pump intake would still be 100% fuel, as that is the part that is submerged. I do not smell fuel while under or around the car.
