JoeLouis
- Jul 8, 2023
- South Atlanta, GA
So, the 242 began to run out of juice, and I got a jump to get me home. I pulled and had the battery checked, confirmed good. I naively thought it must be the alternator, but I put in a new one, and still no charge....
As with everything else on the car, I wonder what is original and what is TB'd already. This is a photo of the alternator I took off ( probably a better one than the new one, but too late now )
The new alternator had an extra wire ( picture below green dotted line) coming from the black box on the back. Is that a voltage regulator? Where do I hook it up if so?
Also, I traced the small read wire that I hooked up above and it was connected at a spade terminal that was unhooked below . Does this little guy ( Blue Circle ) connect to the open spade terminal ( Orange Circle )on the starter?
Tracing from the spade terminal above it goes to the coil below (Red)
Cheers to you for reading, all suggestions welcome.
