I don't think that you understand what I am asking.
Correct, I certainly don't but I'll try again...
Does the "big gap" happen in relation to the 720* rotation when the lobes are in position to lift the valve.
The cam and crank sensor gaps (or teeth) are used for cam and crank position references. The ECU calculates everything from those position references. One of the cam teeth
_might_ happen to be aligned with one of the 6 lobes, but it's not required. What is required is that the ECU has the correct calibration numbers (in degrees of rotation) for the crank 60-2 tooth gap and for the cam VVT phasing.
Let me try a high-level explanation for any modern engine and see if that helps with yours.
First off, the ECU must accurately know the position of the crank so that it can fire spark at the exact right time. The missing tooth section of the 60-2 crank wheel provides the reference. For the old redblocks, this is 87degrees BTDC. This may? be the same on your B6304T4 engine. You will need to find this value and enter it into the EcuMaster setup.
Once the crank position is known, an engine can run fine using either a distributor or wasted spark without any cam sensor. This was common up to the mid 1990s.
Next, in order to run full sequential ignition and fueling, a cam sensor is needed to tell the difference between power and intake strokes. Say that the #1 cylinder is at TDC. It could be at the start of the power stroke, or at the start of the intake stroke. The cam sensor, with a unique pattern, allows the ECU to determine (or sync) to the engine stroke. For example, from your original waveform, the wide cam pulse would occur during #1 power stroke and the narrow cam pulse would occur during #1 intake stroke.
I don't know what EcuMasters supports, but somehow you need to configure it with the unique cam pattern and how that relates to the stroke.
Finally, to add continuous VVT support, the ECU needs to know how much the VVT has rotated the cam. This is usually done simply by measuring the shift in the cam sensor waveform relative to the crank waveform. This means that the toothed pattern for the cam needs to on the inner portion of the sprocket, or simply an extra thin lobe on the cam itself. It should be obvious what's being used, sprocket or cam, based on where the cam sensor is mounted.
The ECU needs to be configured with the min and max VVT rotation of the cam, versus the crank missing tooth section. The EcuMaster VVT wizard may be able to figure this out automatically if VVT is disabled, or locked to min/max rotation.
