Chilm
Double Dutch
- Apr 28, 2009
- The Netherlands
Hi, I have two questions about the 15G on my 1998 945 B230FK:
I modified the oil return line from the turbo, and the line now has an ID of 16 mm.
I’ve read somewhere that this is too large because the oil needs some backpressure.
Is this true, and if so, what should the diameter of the opening be?
Question number 2: I also used the wastegate from a Volvo 850 15G, and it is considerably larger than the one on the 13C.
Does anyone know which spring is fitted in it, or at what pressure (bar) it starts to operate?
Thanks in advance for your comments and advice.
Cheers,
Chilm
Cheers,
Chilm
