Brontes II
- Apr 12, 2021
Hi all,
I've got a super base model 94 940 automatic, and I'm looking at ECU options to increase my idle speed a bit.
Why? The car has a mechanical fan setup. Again why? The e-fan setup had failed/overheated under the previous owners care and blew the head gasket. The repair work on both were pretty sketchy and both the head and e-fan wiring ultimately had to be trashed. I made the decision to "downgrade" to an old-school clutch fan for simplicity and peace of mind.
As far as my idle speed goes, the car is currently equipped with either a 943 or 946 ECU. (I need to open up the bracket again to confirm which.) And it has a target idle of ~600 RPM. It's my understanding that this is an emissions thing and it's a common speed for e-fan equipped cars because the engine is under slightly less load than mechanical fan setups (like cars equiped with the 951) which often run in the ~750-900 RPM range.
I've been able to get away with the factory 600 RPM idle for a while, but it's always been a little anemic, and as I've started fixing other stuff like the A/C and power steering, the idle load has increased and it's gotten to the point were the engine gets a little stumbly when stopping hard or sitting at a light with the A/C going. After playing around with the throttle a bit and trying to cheat the base idle, I'm realizing just how good LH 2.4 systems are at maintaining their target idle speed. If I adjust the linkage to sit in the 800 RPM range it runs amazing and brakes great for a run around the block and then promptly compensates to bring things back to the 600 RPM target.
I'm thinking an ecu from a mechanical car would solve the problem, and I think with 951 is probably the best option since I don't have to worry about the e-fan signal, or cold-start injection. It's normally a 93/Classic 240 ECU, and/or a drop in replacement for the older pink lable ECUs in a bunch of older 240s. Is there anything from a pinout perspective, etc. that I'm overlooking would be an issue with dropping this into the 940? Or are there better options I should consider instead?
Any thoughts are appreciated. Thanks
