HiSPL
Fanking Champion 1993
- Jan 8, 2015
- College Station, TX
Just wondering if all the parts are there to basically bolt in a 7/9 redblock and trans into a 960 shell. Would the redblock motor mount pedestals have a place to bolt up?
Considering every 760 or 260 that came with a PRV got the same treatment it's only a natural progressionWorld's first 960 -> 940 conversion.
Agreed, the whiteblock is a good upgrade. I would love an NA whiteblock in my 242.Why? The whiteblock is a far better design. The cross member is the same one used on a 740/940. So, yes, you could bolt a redblock into a 960.
The 2 models are so different I get the feeling you don't know what you are in for. It is not going to be a case of just drop the redblock in there.Considering going to look at this one, but it's a long drive for me. If the timing belt isn't broken the motor would fit my needs, since I'm going to go through it before sticking it in my 242.
1997 Volvo 960 Sedan 4D
This was a very nice Volvo sedan, it has 165000 miles. It was parked about 6 years ago and is in need of some cleaning and repair. It was running when parked. Turns over with key but does not...www.facebook.com
If I put a B230FT and an AW71 in this 960 I'd have a decent parts hauler so I could keep my current 240 clean.
I would love a wagon, but there just aren't any around without going to the west coast.Are you anti wagon for some reason?
I wouldn't take the effort to save a sedan donor when they make the same car in a 5 door
Only thing I can think of is speedometer, but I think that's driven off the rear end in the 960 still.The 2 models are so different I get the feeling you don't know what you are in for. It is not going to be a case of just drop the redblock in there.
Sweet. I should have everything needed except for the dash. I don't think ours survived the crash. Not a huge deal either way. I don't actually need a speedo to pass inspection here. I've passed inspection using a phone app for speed. I might do an OBD adaptor with a cheap tablet.You'd need to pull the engine mount pedestals out of the 745 front crossmember and put 'em in the 960. (You'll need to remove the 960 pedestals anyway for putting the B6304 into the 242).
Swap the dash cluster over for an LH2.4 suitable version speedo and 4-pot tacho.
That's basically what Mother Volvo did for the US edition of the 940 SE....
Yeah I got that.That’s way off base. There’s almost no similarity between a 960 and a 940 as far as their electrical system and engine management harnesses are concerned.The 960 runs Motronic fuel injection. That uses one computer to run everything. You need to rewire the car in order to have a separate ignition and fuel computer. That means either trying to Kluge together two 9 series harnesses or putting in a 240 engine harness to run almost stand alone. You also have no way to control the electric overdrive on the AW 71. The drive shaft is also different on a 960. If the AW 30–40 transmission is the same length as an AW 71 then you can use the 960 driveshaft.
