Dpm0317
- May 8, 2019
- Raleigh NC
Hey, hoping someone can help. I just replaced my dash cluster. The old one had a weird temp gauge that I could not get to read consistently, a broken odometer, and the connector on the back of the speedo was super glued on. But the arrow relating to the overdrive (its an auto) always worked when I pressed the button on the shifter.
I recently replaced the cluster after cutting out the old speedo connector and replacing that. Now the temp gauge works, the odometer is broken on this one, the service light is on and cannot be reset with the button (Removed the bulb). The arrow is also always on. The car is shifting fine and going into overdrive as usual.
I know the arrow relates to shifting in manual cars - are the dashes the same between manual and autos? Wondering if I got a manual cluster. Why else would it remain on with the "new" cluster when it worked as it should with the old one?
If I can't figure it out I'll pull the bulb, but I love having at least some of those lights working...
