Alan29
- Jun 23, 2019
- Jax Adjacent, FL
So I'm in the final stages of the AW70 to M47 swap on my 1993 240 and I'm running into an issue getting the two piece shaft back together. I am using the 1993 AW70 rear with the M47 front that came with my M47 parts. Both of the AW70 halves separated like they should without any fuss. Joining the M47 front to the AW70 rear is giving me extreme grief. I located the alignment arrows. I have verified there is no weird obvious spline differences. Both halves are meshed together but it won't go in by hand.
After reading they can sometimes be a little difficult to join I stand the AW70 on end and use the magic of gravity to tap the top portion into the splines. Its taking way too much force. Part of me thinks I should just smash it it all the way, but the better half of me knows this won't be sliding like it should if I do that. I return it to my work bench and after some swearing and smacking I get the two halves separated again. This is what I find:
So me forcing it caused some gouging of some kind of plastic/epoxy coating with one rib completely flaking off. It seems like this coating is preventing me from sliding the M47 half onto this.
I've searched and I can't find much of anything about this coating. Was this certain model years only? Any ideas or words of advice?
