Some guy with a Volvo
- Feb 4, 2016
1 sprang an oil leak at the front my motor - splashing a bit of oil over the belts etc. Hard to see exactly where it is, but it's in the lower portion of the front of the motor below the fan, so would I be correct to suspect the front crank seal? If yes, I also noticed that IPD has an entire timing cover with silocone seal (instead of replacing the felt seal. Any thoughts on this?
Thanks,
C
61 544 with B18
Thanks,
C
61 544 with B18
