jens gustavsson
- Dec 1, 2004
- sweden/s?var
any one testing this roller rockers? from vintage performance?
Roller Rocker Arms for Volvo B18/B20 engines - The New Kit Is Here and Easy to Install.
Since the decision to discontinue our old roller rocker kit we have been working on a new one. And now it's here. It uses the stock rocker shaft, shaft pedestals, adjusters and pushrods and will eventually be available in several ratios. Kits currently instock are 1.54 ratio, with rockers in 1.60 and 1.65 ratios projected to be available in 2012 . Installation is simple. Just unbolt the stock shaft, slide off the old rockers, remove the adusters and install them in the roller rockers, then install the roller rockers on the shaft. The only other modification necessary is to change to an aluminum valve cover to provide enough clearance for the end rockers. Introductory price good thru the end of 2011 - $325. With aluminum valve cover and gasket - $450. Both prices will go up by $25 for 2012
Advantages of the new Roller Rocker Kits for Volvo B18/B20 Engines will include:
Increases valve lift and effective duration.
Increases horsepower and torque.
Allows higher RPM operation.
Reduces valve train wear and increases the life of valve guides and seats.
Reduces heat by reducing friction.
Easier to install than other RR kits
Improved durability
Less expensive than other kits
Improved durability
