I would tend to disagree.It looks like a later 9:1 B21F with big rods which I think is a good little motor.
What do you actually want? You just said you were thinking of swapping the engine but gave no reason. Engine swapped cars are not fun to own unless you know exactly what you're doing and you can afford about a year of ironing out all of the kinks. You would be reengineering the car, are you capable of that task? There's not much more you can squeeze out of that motor unless you do all of the work to bolt everything from a turbo redblock motor on.
A friend of mine has a shop that exclusively does this type of custom work, swaps and whatnot. He’d be handling it, if it comes to that. I’d like to get 300 hp (I’d go more, but the rear end might not cope). If I could rebuild the engine (new cam, head work, etc…), maybe add electric fuel management and a turbo and get close to that, that would probably be sufficient.It looks like a later 9:1 B21F with big rods which I think is a good little motor.
How much are you willing to spend on all that custom work on top of the $8k you spent to buy the car at auction?A friend of mine has a shop that exclusively does this type of custom work, swaps and whatnot. He’d be handling it, if it comes to that. I’d like to get 300 hp (I’d go more, but the rear end might not cope). If I could rebuild the engine (new cam, head work, etc…), maybe add electric fuel management and a turbo and get close to that, that would probably be sufficient.
I’m not planning it will be cheap. If I end up doing a swap a 5/6 speed is going in there too… and possibly a rear end. I expect it will hurt a bit.How much are you willing to spend on all that custom work on top of the $8k you spent to buy the car at auction?
It is unfortunately auto as it sits now.A cam and a header would make it a lot more fun, IF it's a manual. If it's auto, you're out of luck without a turbo.
When I here the word "swap" I'm thinking of from a different engine family, like a V8. I agree that a B230FT would be simple enough as you can use all factory parts.I would tend to disagree.
If you swapped in a B230FT with an LH2.4 240 harness, it would be as reliable and usable as any stock turbo 700 or 900.
A great buy on that carI just bought a 1981 262C. It has been swapped with a B21F. I was thinking about swapping the engine, but read that the B21F is over engineered and can handle a bit more power. Any recommendations on upgrades for that engine?
If you bought the black 262C which just sold on BaT, then nicely done! That one looked like a survivor, nice paint and interior. I sure hope the body wasn't riddled with repairs under the sleek black finish.I just bought a 1981 262C. ........Any recommendations on upgrades for that engine?
But then you have to live with t5/tkx noiseI'd just go with a 200hp B230FT. That is plenty of power and it will do so reliably without causing a cascade of upgrades throughout the whole car. With a T5 or TKX transmission it will be bulletproof.
The upside is that it all just bolts in with a bit of welding for a downpipe to fit nicely.But then you have to live with t5/tkx noise
I have strongly considered an ellis swap just to have a quiet transmission
200hp is just 300hp with the gas pedal 2/3rds of the way downThe upside is that it all just bolts in with a bit of welding for a downpipe to fit nicely.
I am also against everything needing 300hp, if you want a reliable and quiet 300hp just go buy a modern sport sedan.
