Back with another update!
Phew, been busy getting a bunch of small things accomplished it feels like. I replaced a burnt out brake light bulb (maintenance ftw!)...
Ok, that was a bit of a joke. I just now got done installing and wiring up my new to me turbosmart eboost street electronic boost controller. I just have 2 hoses to buy and run to the solenoid, and it's complete. (Read at the bottom on why I ditched my hallman pro mbc)
I picked up a spare squirter engine. Aaaannnnd it's totaled lol. I ended up getting it for free, but when I got digging into it it's got a crack at the bottom of one of the cylinders, and a chunk taken out of the block. I plan on sticking my borescope thru the oil plug on my current motor, and see if it's at least got the holes drilled and tapped with bolts in them (I doubt it, especially being a 1991 but gotta check). I'll at least be able to pull the squirters out, and the round tooth crank and one cam gear. Might be a good excuse to order an.adjustable cam gear for a round tooth, and use the blown motor gears for the aux shaft and crank.
I also have ordered a 3" angled downpipe from Lucacarmods. I couldn't stand looking at my own welds, especially with car show season among us lol. I'm sure my welds aren't leaking free. This will also get my O2 sensor off the firewall since it is very close. Also a good time to get a bung welded in so I can hook up my wideband and be able to actually see what's going on.
So my hallman pro was a vacuum leak. Verified with a hand pump it would not hold vacuum, or pressure. You could still set it and it would still open at the set pressure, but below that pressure with the ball " closed" it was still leaking by. I ordered a new spring and ball, replaced them, and same thing. I then tried cleaning up the fitting the ball seals to, made it worse. Went to the store for a new 1/8" mip fitting, same thing. I gradually polished the face up and it did make it much better, but it was still leaking by. I found the turbosmart ebc on FB marketplace for a good enough deal, so I jumped on it. I do have one question regarding it so far, but will make a dedicated thread for that
