Crustacean Wagon
- Sep 29, 2020
- Hadley ma
F
And ill die on that hill with you
Ill be here with your 14.99 in an envelope ready to mailYou're first in line! I'll have to update this when it's all back together on how it performs. It's been hitting boost at like 3k rpms, but I remember it coming alive sooner on previous setups. Hopefully that nipple being loose was the big change.
It's got a lot of "goodies", but was originally put together for a whiteblock so my approach was pushing the boost and power further up the rpm band. It's got a 9 blade turbine wheel, billet spool control compressor wheel and conversion housing, and an ard adjustable wastegate. I rebuilt when I put it all together. I'll probably try to sell it as a package with the angled housing and downpipe whenever I do upgrade, probably a while out still
I definitely do need a new kickdown cable. Mine sometimes moves within the outer sleeve, so I have to keep an eye on it. I have considered just biting the bullet and replacing it, and doing the accumulator mod while in there, but with how little miles I put on the car I've just kind of been crossing my fingers. I do have a lot of the bits needed to t5 swap though. I know the shifter is pretty much the Achilles Heel of this swap, but I feel confident enough in my fab skills to be able to get something that'll work. The other two "hard" parts of the swap to me would be the cross member and driveshaft, which I've already got those as wellDo the full IPD trans fluid swap on your AW71.... buy a new cable and adjust it properly. These actions combined have restored more AISIN transmissions than we will ever know; they are actually pretty stout. The T5 in the 7/9 chassis is a much harder conversion due to the shifter location and knuckle/dash collisions. I've seen folks remove the covers in front of the fuse block just so they could shift!
