I've been away from home for about 2 weeks now, but my wallet and mind has been busy with this t5 swap.
My viggen clutch kit is at home waiting for me and the pilot bearing should be delivered today.
I went ahead and bought a countershaft bearing support plate for the t5. Apparently this is one of (if not THE) best upgrade you can do to make a t5 last. It's supposed to hold the shaft and gears tighter to prevent them from walking apart, which is usually what kills these t5s. In doing this upgrade you must remove the shifter. I figured since I'll be in there, might as well get a short shifter...
So I bought a used short shifter off eBay. I've heard awesome reviews for the MGW shifter, so bought it, although it was admittedly too hasty. My shifter relocation idea has been thrown out the window.
The stock t5 shifter attaches the handle on a flat of the shifter stub, that has 2 bolts holding it. Search the MGW shifter, and you'll see this unit the shifter.is a post, and the handle attaches via a pinch joint, like a shaft collar. I have an idea on how to make this work and get it extended rearwards though.
Convert any standard SAE automotive battery post to JIS Japanese Pencil Post with our SAE to JIS conversion adapters. 850250 - Negative.
remybattery.com
Same to jis battery adapter. I am unsure if the opening and post are the same size as the MGW one, but I can get creative here. I'm sure I can use bushings in between to get to the correct width. I will have to take some measurements once I get back home and have some of the parts in hand, but my goal is to come up with a clean shifter solution for 7xx/9xx series that anybody can do. I'm sure the adapter linked above can be cut and an extension added to get the correct length, but again I'll know once I get parts and everything in my hands
Next week Im scheduled to go to the other side of the country to PA and than NC. Probably going to be stopping by BNEs shop with my flywheel in hand so I can have him do the machining on it for me. Might pick up the throw out bearing and adapters while I'm there.
I still have to iron out details with California Clutch, but that hook is just about set for the clutch disc too.
I am going to try and get pictures of everything during the swap. It seems like there are so many gaps in 7xx/9xx t5 swap write-ups. Id like to be able to make this as easy as possible, as I'm sure there are plenty of people with these cars that would love for it to be manual and not worry about the transmission lasting
