CAPT_BLOTTO
#Crush It
- Jul 19, 2005
- Kansas City
77 240 with b230 E85 big turbo LS coils running microsquirt.
I've finished up a wiring project and spent some time checking all my inputs and outputs before starting the car after it has been sitting for months. Car was running fine before it sat. Got the car started, barely, and the AFR is saying it's full lean. Car doesn't sound the best and I can only get it to idle while holding the throttle open. When I let off the throttle it starts popping out the exhaust. The flex sensor is also fluctuating a lot I will look at the ground wire. There might be multiple things going on but I attached the log file of a cold start to get some help on what might be causing it. It has an AEM wideband with the LSU 4.9 wideband. Is there a way to tell if its actually bad?
