mopar318
- Apr 8, 2013
- Fort Wayne
I've been having issues this year with ethonal, so I finally added a flex fuel sensor.
Things got a bit confusing here because I always from the start tuned the car on e85.
The sensor was reading 75% e. After setting the flex settings base map to e85 it was apparent that my base tune was around really about 77% ethonal. With the base map set to e85 and the correction at 75, it would run so lean at idle it would stall.
After a quick adjustment the map correction is perfect again.
I'm very glad I added this sensor. The ethonal content makes a much bigger difference than I thought for idle/driveability. If you aren't running analyzeefi of whatever Everytime you use new e85, would be impossible to tune.
