noz-e8tr
- Aug 27, 2003
- Ocean Springs, MS
You are correct, you didn't mention 90mm. My tuner is always pushing the whole "bigger is better" thing every time I go in. He's all about peak HP. I do have plans next year to fit a single turbo with around 5-7psi boost. I'll address the intake and TB at that time. Didn't want to do it twice. I think 325-350hp is a conservative estimate and will be a big jump up from the stock 214hp. I'll have to learn to drive it all over. lol I do appreciate the feedback BTW. I have my set plan, but I'm always open to suggestions.
I wasn't thinking of peak HP numbers either - I'm aware of your application. I've got a fair amount of time in with these motors. Bottom and midrange can also benefit from a proper opening up the lower. Not sure where a 90mm throttle body suggestion arose - I'd go 75mm; modulation won't be a problem. But - sounds like you have a plan, so good luck with first start and run-in! Your changes will make a big difference. The (similar) AFR165 heads really woke mine up.
