Blinker turner offer
A couple shots of WD40 into the switch mechanism solved a non-canceling issue on a PV544 that I had.
Might be worth trying.
Thanks! I did try that with no luck. The plastic part looked pretty buggared up when I inspected it.
Just make sure the parts you're getting are what you need.
IIRC, a '68 140 has a different turn signal switch than a '69 - '72.
So it's possible that the plastic piece you're looking for may be different as well.
Do your homework.
Very early looks different but is functionally the same 67-72.
One year only for 73 and unique again for 74.
https://forums.turbobricks.com/showpost.php?p=5066201&postcount=2
