With the 530 head? I dont want to 16V it, unless i HAVE no other choice
Why not? It's fersure the easiest way to make sure you get or exceed 500 bhp.
Do some simple math. Do the area for the 1 intake valve and 1 exhaust valve choosing say 46mm intake and maybe 40 exhaust.
Then do the areas for
2 intakes at 34mm and
2 exhausts at say 32mm.
Compare the areas, and do the per cent differences.
REMEMBER THAT THE AREA IS ONE THING, THE PORT LEADING UP TO IT IS EVERY BIT AS IMPORTANT.
And then think if its worthwhile spending huge amounts for a 2 valve head when you DO have the option of the 4 valve.
The only problem of the 16v is cost, and you say that's not a factor.
So.......................
For truly silly numbers, get a B23 and start from there. It has a forged steel crank and is plain LARGER everywhere.
Run a 16v head, 30 psi boost, a correctly sized turbo, mod the plenum of the OEM 16v manifold, buy my 6.3 c-c rods and the nice designed CP Pistons, and then spend some money pn the flywheel clutch, trannie and REAR AXEL
It is all unfortunately all a package, and you may as well plan for the whole thing.
There are sub 8 second Volvos at 2.5 liter.
