CAD for240 Custom brake rotor hats to match wilwood disc
Majshumlan
Hi
Im looking into doin some alu hats for wilwood rotors to fit a Volvo 240.
I can have them done for free at work and heard that someone may have done something similair here and a CAD file would save some time.
Any one out there having a cad file I could grab?
Cheers
One of our members is already building those... and is offering a lot of products to support our little community of Volvo nuts.
Ok got it
I guess he/she may wanna keep the cad for their own.
I put some time and CAD it up by my self then
30min CAD on the lunch and then sent it down to the guys in our shop.
You’re going to want to have the rotor vents on the inboard side, and less offset on the hat. You’re going to overheat the rotors if you’re running them hard.
First
This will not be sitting on a Volvo, just a Volvo spindle.
Quick judgement to say it will overheat if you dont know anything about the setup or intended use.
Second
I will mount and check first and then put it on Grabcad or similair. But this will not fit a standard Volvo hub as my is custom and abit smaller. Im all for helping others if I can.
chee😎
First
Second
chee😎
This has nothing to do with being on a volvo spindle or not. This is about you blocking the internal veins with your hat design.
Airflow veins are open on the backside and will have a airduct connected.
What I meant are that a low weight car will put less heat on the brakes. This will NOT overheat in my setup and intended use
You might be surprised what a downhill road will do even in a light weight vehicle like a Locost/Super7.
Hat looks good, and it looks like a fun project!
