Kaleo Ake
- Dec 2, 2024
Hello, I’ve been struggling for a while chasing down this issue with getting power to my pump. Car is a 1972 142s. So car was running before just about a month ago and then it wouldn’t start again. I’ve done a bit of diagnosing and found that my fuel pump relay was getting no power from all terminals in the relay. The main fuel relay does get power though. I’ve sent 12v straight from the fuel pump wire to pump and I could hear the pump and car would fire then die. Ive inspected the fuel pump wire all the way down to the pump and everything looks good. I’ve replaced both relays and that didn’t work. I knew I had an issue probably from the battery to the fuel pump relay. I’ve looked into the distribution block and cleaned all the connections. I’ve also checked the little fuse junction on the inner fender of the drivers side and the connections there look good. All fuses inside the car are good as well. Anyone know about these early fuel injection cars? Any pointers would be appreciated thanks!
