t5rguy7
- Jun 14, 2006
- Rehoboth, MA
Since Haynes sucks sometimes and doesn't tell you these things, and since someone FORGOT to mark the position before he took the flywheel/ring gear/timing ring off, I found a hit on voca that says- "58 holes in the timing ring, with a void of 2 holes (room for 60 total). The void will be at the bottom of the starter opening (you can SEE it, at the bottom of the opening, if you were looking at it straight on) IF installed correctly.... while cylinder 1 is at TDC."
I'm really hoping this is true, already mated the motor and trans back together real nice, but waiting on install until i hear from my trusty TB friends with more knowledge than me
Thanks a ton in advance.
