Can I use an 85’ B230 in my 92 740?
chronicrhythm
Colebrook, CT
I know I would have to cut a spot for the crankshaft position sensor but I wasn’t sure if there is a factory spot for a knock sensor or that would have to be tapped as well? Thanks
Should have all those things / I installed a spare freebie ‘supposedly known good’ ‘85 shortblock in a ‘92 w/a rod knock that was ‘known bad’ :lol: ?
So it must have the spot drilled for the crank angle sensor.’
Knock sensor was the Chrysler type on the ‘85 from a 240, but threaded boss same / drilled to install the later Bosch EZK knock sensor.
It was a quick & dirty ‘pull the car in Friday night and be done by Sunday afternoon ‘don’t hack and maim / no huge need to hurry but be nice to get it done before you have to get ready for work Monday morning Sunday afternoon but don’t strictly need to finish by then’ kind of thing?
I left the exhaust manifold on the head / don’t mess with it or the studs and broke it at the head pipe & left the auto trans in it and bungee cord held the intake to the driver hood hinge and a/c and PS bracket over to the battery tray, respectively & swapped the shortblock only on the quick and frugal / disturb as little as possible, but of what you do touch, make sure you get it right?
I did replace the oil pump transfer tube o-rings / examined the rod bearings and rednedk leakdown tested the pistons (face up and halfway down with atf measuring leakage overnight) as the engine was partially unknown and sat around a while and installed the later tall gear oil pump / was careful with what I did touch, but controlled costs, time, effort & uncertainty as much as possible / ‘I’m not restoring it’ but did do the swap in a carefully considered way / would feel like an idiot not replacing something as cheap and buried / relatively inaccessible as those o-rings w/o another easy opportunity to change them , the pump and sump gasket and rear crank oil seal.
The rest..’ehhh, as needed’ / is accessible easily enough in chassis.’
I did wire wheel the head to manifold studs and put some silver anti-seize on them after letting them soak for future removal, but didn’t want to disturb the head-manifold gaskets that were sealing fine / not ticking?
Thanks for the big reply! Good to know it will work. That is exactly the route I want to go. Not looking for a big build or rebuild since this is my usual daily when there isn’t salt on the roads. The piston slap on my engine is so bad now it sounds like a diesel haha. Still runs strong now but I don’t think it would be a great idea to put a new head gasket on it at this point since it’s pretty tired.
