It's my turn!
My recently installed Dellorto DHLA 40s are giving me quite the headache, literally.
Setup:
Dual DHLA 40s, non lettered early carbs via:
For sale post
-55 idle jets in currently
-210 air correctors
-135 main jets
-32 mm chokes
Carbs baselined per typical DHLA setup, 2.5 screws out on idle screws
Volvo Comp Services intake
Throttle linkage setup
Misab vibration style carb mounts
Holley FPR set to 3 PSI
Facet 40007 Fuel pump
123 Distributor set to 12 BTDC at 1K RPM
Ran the valves to .016
I am having quite bad backfiring issues with the carbs. Full on
fireballs out the intake.
Its really rough starting as well, can't get it to idle at all. Not using the choke mechanism at all.
The carbs appear to be quite wet in the barrel when I go take a look, also appears to be some wetness on the throttle shaft?
I've read that this can be a lean issue? This setup should be set to run relatively rich from my understanding.
Previously this car had a Weber DGV 32/36. While I wasn't a fan, it never exhibited any backfiring issues like this.
Would love any help as this car needs to drive up onto a trailer in about 3 weeks and I would prefer to not have to put the DGV setup back on.
