Carburetor Tuning Thread for B Series
I'll post what I am running thus far. But I'm really just getting into tuning this engine. Just got this car/engine combination running this winter.
1966 122S with a B20 and M41 and overdrive conversion. I'm located in Colorado at 9-10,000' elevation. So that is affecting my tuning quite a bit.
Engine:
  • B20B bored to .040" over, decked to 0.0" +/-
  • Lightened flywheel
  • .036" Cometic HG with same tight squish +/-
  • E Head with 38/44mm valves, mild porting, double valve springs, 45cc chambers, 11:1 compression???
  • Tinus Tuning TT4N cam, with his lifters and pushrods
  • 4:2:1 header into 2 1/2" exhaust
  • Stock SU manifold
  • Open Cone filters
  • 123 Distributor
Carbs:
  • 42mm dual Mikuni's
  • 22.5 Pilot, air screw 2.5 turns out
  • 180 Main
  • Y6 needle jet
  • needle raised 1 notch (richer)
Running 17d advance at idle, max 34d
Just installed a wideband O2 and AFR gauge, still trying to figure out where I want to be with this motor at 10k elevation. It's idling around 14:1, WOT is in the 12-14 range, light throttle cruising it seems to be running rich right around 11:1
