Chinese Water Torture (a SeaFoam recipe)
a SeaFoam recipe
This procedure when properly administered has been proven effective at improving power, and for some, fuel economy and other various improvements. While these results are usually immediately evident, not everyone who has run this procedure has had results that they could measure or feel. Be prepared for lots of steam and clouds of smoke to accompany this. *click for pic* This procedure is routinely run on a wide variety of cars regardless of make, model or number of cylinders, including Turbos, all with no damage. It is ideal to do this procedure just before every oil change, or at least once a year. Changing your oil soon afterward is ideal, but is not mandatory. Properly administered this procedure will not significantly contaminate the oil or cause any change in oil consumption rates.
<hr>
Ingredients:
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere07.gif align=absmiddle> 2.5 to 3 cups distilled water
You can use tap or bottled water if that is not available, if you are working alone the ideal container will easily stand up on it's own, not a plastic soda/water bottle. Suggest: 1 qt mayo jar / Mason jar / spaghetti sauce jar.
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere07.gif align=absmiddle> 1 can of SeaFoam (16 oz) *click for pic*
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere07.gif align=absmiddle> 2 to 2.5 feet of small vacuum line, 4mm (5/32")
<hr>
Procedure:
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> Preheat the oven: Always start with a fully warmed up engine that has been running, preferably driven, for at least 20 minutes. Then park where you will be up wind of the car's exhaust, leave it running, or turn it off, but dont leave it off for long.
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> Locate a suitable vacuum port and connect your vacuum line, this will be a small nipple, around 4mm in size with good vacuum at idle, where possible down stream of the throttle body. Do not use any large ports such as for the brake booster *click for pics*
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> (Assuming your are working by yourself) Place the jar of water where it will stand on it's own, hold the throttle around 3000 RPM, best guess, and with the other dip the vacuum hose into the water. Use a rhythm where the hose is submerged for 1/2 second, and lifted out of the fluid for 1/2 second, repeated until all of the water is used up, while at the same time regulate the throttle to keep the engine speed around 3000 RPM as it will run rough.
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> Repeat using the SeaFoam. I recommend using an entire can for this, others have reported good results using between 1/3 to 3/4 of a can, then putting the remainder in the gas tank. During this process, Turbo cars seem to like to leak at the manifold, either between the head and manifold or between the manifold/turbo junctions...don't worry...it will seal back up after you run the car for a while.
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> It is recommended, but not required, that toward the end of the process you allow the engine to stall. This is done by dropping the throttle, leaving the vacuum line submerged in the SeaFoam, and allowing the engine to stall. An alternative and possibly better method may be to drop the throttle and immediately pull the hot wire off the (+) #15 terminal of the ignition coil, or if you have a helper, switch off the ignition. Then let it sit for 5 to 10 minutes. Then crank it up, and finish feeding in the remaining SeaFoam.
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> Then right away take the car out for a rev fest, here you want the tachometer to reach redline several times, stay in low gears. You should immediately notice the improvement in power.
<img src=http://www.threefattigers.com/Protocore/FunStuff/sphere01.gif align=absmiddle> Optionally you could run another can of SeaFoam in the tank, and then if you are planning to change the oil, wait until after the tank is run down, reason being most fuel injection cleaners run through the tank will tend to darken otherwise clean looking motor oil.
<hr>
As for SeaFoam substitutes:
You want to use a product specifically designed to be fed through the intake manifold, they are commonly known as top engine cleaners, it must be oxygen sensor safe, which SeaFoam is. GM makes a top engine cleaner, Mazda does too, these are designed to be fed into the intake manifold just as this procedure describes and should produce similar results. Another alternative that I know of would be Lubro Moly "Ventil Sauber Valve Clean". I do not recommend using Barymans Chemtool (B12) or any other carburettor cleaner. I recommend using SeaFoam wherever possible.
Additional information can be found here: http://www.seafoamsales.com/
My initial experience with this procedure is documented in this post I archived from Miata.net:
stylngle2003
Two Up, Two Down
as something to add that i have noticed being that i have foamed 7 bricks now
turbo cars seem to like to leak at the manifold, either between the head and manifold or between the manifold/turbo junctions...don't worry...it will seal back up after you run the car for a while...trust me! just make sure if you are under the hood that you can get nice fresh air...im sure all the smoke i inhaled this weekend couldnt have been too healthy for me :oops:
great writeup TFT!
Eakin
Toronto, ON
I did this last night on my 740. I can't find Seafoam in Calgary, and from what I've gathered, no one else can either. I opted for the GM 'Cleener' or something like that. The instructions were for a carb engine, so I'm not sure if it's 100% safe with my O2 sensor. It did work quite well though. Gave my street a little smoke show. I ended up pulling off the vacum line that feeds the turbo gauge. There was a little connection just before it went in to the firewall. It was the perfect length and then I just added a bendy straw on to the end of it and stuck it in to the glass of water. I followed this up with an oil change after running it through the gears for an hour or so.
Thanks for the great write up.
Beanie
Bored Member
NJ
Where's the smoke?
How important is it to reach redline on the drive after? I did the procedure as directed above, with not so much water, and during, I accomplished the manifold smoke. But I have no resulting smoke on the higway. Is it because I didn't let the Tach go over 4,000?
EricF
Volvospeed Spy
St. Pete FL
Awesome, I think my car is a great candidate for this... Can't wait to test it out.
Just need to find a neighborhood I don't like where I can park for the duration of the procedure :-D
I'll edit any input I can afford after I do this, into this post.
MetalgodZ
Bored Member
I've done this quite a few times, and it works very well. I have dont it with B12 Chemtool as well (listed as a fuel injector cleaner as well as a top engine cleaner) and it worked somewhat well on my '29 242 and my g/f's '93 940. It DID NOT work well, initially, on my friend's '98 S70. The S70 chugged and choked and didn't rev right for about 3 days and my friend almost kicked my @$$ for convincing him to do this, but after 3 days it started to clear up and ran better (slightly, but not much) than initially.
This MAY be due to an oil change that we did afterward. (Turns out he was running 1 1/2 quarts low as well. :-O)
Stay away from the B12 Chemtool as a Seafoam substitute though.
DoubleV
Newbie
Davis
Absolutely great write up TFT!
I just have one question.
I just changed the oil on my '92 940 about 1,000 miles ago. I used Mobil 1 15w50 and usually go 5k before each change. Do you think I'm safe using Seafoam and not changing the oil for another 3,500-4,000 miles afterwards?
Thanks.
I've not personally observed smoke from the exhaust after a minute or two of completing the procedure. It's not critical to see redline, it is ideal though, and easily achievable at slow speeds if you keep it in lower gears.
Yes, but you might want to skip the stalling & soak part. I've run this procedure both with and without the stalling part on the same car, and for me, either way the car ran notably better after. Between the two methods, I don't think the seat of my pants could quantify a difference in performance, but then they are low mileage cars that have seen this procedure before.
U
Unregistered
Guest
foam the cat
just wondering -
I just did this tonight and yep much smoother and more responsive. but has anyone, especially those of you who have been Foaming the same car for a while now, noticed/suspected any damage to the cat converter from this procedure?
thanks for the tip -
96 850 wagon
it's blue
SwedishFish
Shreveport, Louisiana
my cat smokes
I tried this today.
My idle cleared up very well, however(yes that evil word), since my cat is original, and most likely partially clogged (its a smoker, and the temp after it was above the temp in front by 45* F), no copius amounts of smoke exited my tailpipe. I did get the smoke from my manifold/turbo junction as per normal, but like i said no copious smokeout. Bad clogged cat! Bad!
*when i say my cat's a smoker, i mean literally aftern shutting the car down you can look underneath and see smoke rising from the outside of the cat. never seen this before...and am very confused. oh well 3" pipes here i come.
karl_760ti
South East Victoria, Australia
Just to clarify, all this seafoam/water does is remove carbon buildup on the back of valves/in combustion chamber.
Therefore it will prove most benifit to a older car with lots of mile driven by a granny who never goes past 3k.
It will benefit least to a car that dosnt have as many miles and sees redline often.
Logically I agree, but my real world experience disagrees. I run this procedure on my Miata at each oil change, and every time I can feel a notable seat of the pants improvement, and this is a car that sees redline nearly every single shift where traffic allows, and also sees sustained high RPM every day. This is also a car that is driven very often but rarely for only short periods, say less than 30 minutes. If I can reach that 7400 rpm rev limiter I'm in heaven, I trigger it on purpose as the sound of the engine cutting off and then back on again is amazing in that car.
All? of my every day cars see redline quite regularly, and all? are low mileage, and all? respond to this treatment with performance where I can feel the difference ever time I run this procedure.
