Is higher octane fuel required on LH 2.2 models (with just a fuel chip, and no EZK chip)?
No, high octane fuel is not required on the LH2.2 models, but
highly recommended.
There are many drawbacks of using low octane fuel with the chips:
* You need to run more retarded timing, loosing power, efficiency and mpg.
* You can?t run very high boost, and if you wanted to, then you would have to retard the timing even more. Then it would be a useless investment and a waste of engine resources.
Have you tested these chips with the Mitsubishi TD04 Turbo? Since they produce hotter air at the same boost levels than a T3, I would expect that they would require a richer fuel map to compensate.
The chip for the LH2.2 has the same basic software layout as the LH2.4 chips, but the LH2.2 chips are made specifically for the '86-'89 700-series. So it has been covered.
These chips are not something that is only tested or made from the tests on one or a few cars. The chips sold have thousands of hours of driving/testing/dyno-time behind them, many thousands of dollars invested, they are tested and developed on
many cars (50 perhaps?), and are a result of what works best on the average car in the series which the chips are made for.
The LH2.2 chips on the other hand doesn?t have such extensive testing behind it, but it is still the same engine so it is not so hard to adapt it from LH2.4 to LH2.2. Since the chips already exists for LH2.4, it only takes testing on a few cars more in order to see that it works with the older engines as well.
