Hi Henrik, also if I feel me much confident with LH systems than K-jets ones I don't agree with tbrcktch since swapping the injectors cannot tell you anything about the state of the fuel distributor. Also if is only an hypotesis, an uneven flux of fuel to the injectors could explain why you have a missfire in a specific cylinder.
That's why I suggest you to check the k-jetronic system running. Take a look at this video, but I suggest you to use 4 single bottle and not one big like he did
Regarding the timing gun I don't think that is a good tool to diagnose a fouled spark plug nor is good a spark tester (the light or the gap electrode tools that you put in series to the spark plug).
Es.
View attachment 23081 or
The problem with those tools is that in case of a fouled plug the electricity flows near normally into the HT leads but doesn't jump throught the electrodes and that's why the mixture doesn't ignite.
The only ways that I know to detect a fouled spark plug is to change it with a new one or to check the secondary signal with an automotive scope but unfortunately only a few people have one and are able to use it.
After having verified that is not a wiring problem and the plug makes the arc I suggest you to make this simple test: remove all the spark plugs and the fuel pump fuse, crank the engine for a few seconds to clean all the combustion chambers, install a new spark plug on the faulty cylinder and reinstall the other plugs, reinstall also the fuse and crank the engine. If the problem is no more present it could be due to something that prevents the spark plug to do its job (water, fuel or oil).
Finally, compression could only be one of the causes but it doesn't means that is the cause.
It must be checked anyway.
You say that it is solid but I'm generally a bit skeptical in checking compression with standard manometers since I think that it must not be so difficult to reach acceptable maximum values by letting the piston to compress the air many times throught a one way valve.
In the past I remeber some professional compression tools that were able to trace the pressure on charts when the engine is cranking so that it was possibile to see how fast the pressure grows up and not only to get a maximum value.
Es.
I don't think that you are using a tool like this one but may be I'm wrong. In this case I'm sorry.
Diego
