Greetings,
I have a really bad cold which means two things: 1) I cannot smell the exhaust and 2) I have to stay indoors today and possibly tomorrow for any chance of recovering. But once the engine warms up, there is no visible smoke and my hand doesn't get wet from the exhaust.
But, I did a leak-down test yesterday and I also changed the coil out for an NGK coil measuring 1.1 / 8 kOhms. I also cleaned up the ground connections, but it made no difference.
Before I started the leak-down test, I noticed this, though, which it has not done before:
I just don't get what is going on with this engine.
Here are the leak-down test results:
So, it's all very odd, as always. The dead cylinder #1, has the least leakage. But they're all ok, I think, also bearing in mind by the time I did the test, the engine was no longer hot.
I did notice though, that on cylinders #1 and #3, when I initially put my ear to the expansion tank, I heard a gurgle. But only right at the start, it never did it again, and I may have been too slow to put my ear to it with the other cylinders.
So, in-conclusive, again? Or is there a block deck/head-gasket problem?
Once my cold is gone, I will test the injectors and do an inlet smoke-leak test. I will also remove the fan belt and run the engine to be able to pin-point the smoke from it.
Regards,
Henrik Morsing
