3. Powertrain reliability: (continued)
a. Perform thorough stage zero on current Regina redblock powertrain - near term
Any DD worth it's salt needs to be reliable. I continued along the proper stage zero path to remove worn out /degraded items and replace with zero mile (or lower mile) parts.
With the replacement 1041 rear end installed, and a 19mm rear wagon bar from my hoard installed, the rear assembly was nearing completion. As bought, the parking brake adjustment was funky (2 teeth max) so I disassembled all and readjusted, greased both rear wheel bearings while it was apart. Everything torqued to spec and now waiting on my replacement rear calipers to arrive (one rear ATE 38mm piston was frozen). Here the new IPD overload springs and sway bar installed and ready for service:
Also as bought, the wagon had no speedometer/odometer for around the last 50K of it's service. Upon inspection, the rear speed sender had wiring which was seriously degraded. When I bought the P-a-P replacement rear end, I harvested that sender and cable assembly. Must be an issue with those years of wiring harnesses ( or the location of the rear harness, degraded by combustion fumes or ?), as the replacement was also degraded. I want a proper functioning speedo as well as cruise control for traveling, so I set out to repair the lower mileage cable I harvested. Here you see the insulation degradation of the white/green and brown wires at the sender connector:
Bare copper = "
no good condition" as my Japanese friends say.
My plan to remedy this insulation breech while not adding excess mass to the harness, I cut out about 10mm of copper and crimped in tinned copper connector size 22-18AWG, then lightly soldered the 18AWG wires to the connector. While the wire was cut, I slide a 50mm long sleeve of red thick heat shrink tubing up inside the factory cover (keeping it far enough away from the soldering to shrink it):
Once both wires were spliced & inserted, slide down the heat shrink and put my heat gun to it:
Slid the larger grey sleeve of heat shrink over the factory sheath; once I confirm function I will shrink that one down to the sender connector to support the added mass of the tinned connectors (always use these IMO; the best method is crimp-solder-heat shrink). Not shown, but after the sender and harness were reinstalled, I filled the 1041 with the 1.5L of GL-5 gear oil.
Another drivetrain reliability task awaited; as bought the front driver spindle hub had a bearing issue. It was apparent someone tried to insert some grease under the cap to remedy; as these bearings are sealed inside the hub, you really cannot do anything other than R&R. Fortune smiled on me as I found the last SKF OE type hub assembly on eBay (prefer not to use the CHINA replacements). The greenbook tells you that the 36mm hex lock nut is a "one and done"; had a time finding one but finally TASCAPARTS came thru an the German made replacement nut:
When viewing the 7/9 Maint. Pages hosted by the UK Volvo club, you will read testimony to changing these hubs and attempting to torque them to an impossible Volvo spec setting of torque & rotation. Teller of said tale states " he recalls multiple 1/2" drive breaker bars snapped off " in attempting to reach the spec. To that end, I bought a 3/4" PROTO breaker bar and matching 36mm 6 point impact socket. Using my trusty 2' pipe extension, I put my full weight on that locknut and it isn't going any further. In hindsight, I could have saved some money by changing my repair strategy to installing a P-a-P front strut for $50......
c'est la vie. I know the new hub is good for the life of the Vaggen.
Got to get new front rotors, then brake calipers and pads installed at all corners. Finally, reassemble the air box, "custom inlet pipe" and filtered air hose back to the throttle inlet. Once all that is done, should be time to fire up the Regina/Rex machine for some shakedown driving around the neighborhood. Sure hope the speedo function is restored, we shall see.........
