Video doesn't work for me. Any chance for a direct link?
Congratulations, it must be a great feeling!
I'm currently in a similar place with an equally silver 960, finally stopped procrascinating after 2 years:
I think I'll first try to read the oil temp with a gauge and if it's okay I'll let it like that and keep an eye on it. If it's not okay I'll see...
Do you think it's dangerous to drive that thing since I don't know about the oil temp yet?
About water temp sensor, I don't know if I understand well your point of view. To me it works great that way, it is the original position on a D24 and on a AAT/AEL engine for temp sensor, at it seems to work well in every situation. But maybe you're right, I know that on the 1.9tdi A6 C4 it was located on a heater hose. But I do have a heater control valve...
I bought a 90° elbow for upper cooling hoses, hoses come from and audi 80 I think.
And head to heater hose interfered with the shed so I had to buy a short silicon reduction elbow (22mm to 16mm IIRC) and a 16mm junction to fit the original heater hose.
Yeah, it looks and sounds great! What timing setting did you use? Seems to start well and run clean even when cold.
Awesome how many D24T parts you were able to use on this, throttle linkage, fuel filter head, cooling system etc. Terrific results!
Did you leave your springs and shocks in place? Could be a shock, bushing, or mount?Still have some "cloc cloc" noises at the rear when driving slowly on bumpy roads, any idea of what could it be?
Glad to hear you are having a nicely working system!
5,55l, nice! Lowest I did with mine was 6l. But im sure mine is capable of this, aswell, i just have a heavy right foot.
How is your engine sound? I've found mine not being too 5 cylinder like, but rather just an old commercial truck.
Any other 2.5TDI I tried (V70, Audi 100) had nice 5 cyl symphonies, but not the 940.
Great update and results. 42 mpg fuel economy is amazing in a car of this size. The highest I have ever seen in a D24T powered Volvo 700 series (with M46) was a long summer trip that averaged 37 mpg over several tanks. Guarantee your setup is much more powerful and uses less fuel.
The voltmeter was equipped in every stock 740 Turbo through 1990 so should be fairly easy to find, here in the US at least. My local junkyard probably has 5 of them.![]()
