Diesel swap
Those oil temp gauges were most often seen in the V6 B28F and B280F 760 and 780 cars I believe. They do exist.... what I am not able to remember for certain is if they are intended to install in the upper left of the gauge cluster (like the voltmeter does) or the upper right (in place of boost gauge).
That is interesting to hear reports from both of you on the noise and refinement of the 5-cylinder not being as quiet or smooth as you had hoped for. I guess this is probably the only advantage the 6-cylinder D24 and D24T still have..... :-)
Yeah but the D24 is also loud sounding, AAT/AEL on Audis are surprisingly smooth and quiet for mid 90's engines!
Thanks for the gauge info, I gonna try to find one but it's not gonna be easy. According to this picture, it's going on the left corner.
PodZXQaz0J-BgTwJ684eLtI7QTWYcANX8DPG4sT70-WXacHx14-2DFKlHzaRPbIkEJI_ggQG1VUbspTIEwUNIfSggnA1nH0_cuPauw
To me its not necessarily the loudness that bothers me, but the lack of 5cylinder noises. Maybe the loud operation hides it, i do not know. If this is 100% the reason and i knew this beforehand, i would have certainly started with an electric pump... :D
Do it! so we can be sure the problem is the mechanical pump! (my brain is not ready for such modification...)
But I remember my Audi A6 AAT has less 5 zyl smoothness than my friend's AEL, every engine is different even with an electric pump!
What oil are you running on this engine?
I'm sure you do not want to touch it now, even after 4 years im still in this state :)
But its one way to find out!
I use Elf evolution 10w40 700 turbo diesel. So far no issues, lifters seem to be quiet, survived trackdays too.
Hi!
Car is doing great after 4000 kms with it since it was "finished" it April.
Just did some small improvement on it, installing an oil temp gauge as some of you advised me to do.
Not really beautifully positioned but it's just OK for me.
I was astonished by how well though is the fuse box in this car, very simple to remove, and you can ad or modify whatever you want in it very easily! I chose fuse number 13 to wire my gauge as it is an ignition 12v + 15A. They are also a bunch of negative emplacement available.
I also found a voltmeter on a local market place to complete my square body instrument cluster :
And an antenna, bringing me back the radio after 8 years :
Still have some issues to fix :
- Rumbling noise during picks of torque in 3rd and 4th gears mainly, suspecting axle bushings to be to soft for the torque.
- Drone noise at 110km/h, suspecting central driveshaft bearing / driveshaft unbalance or misalignment
- "cloc cloc" noise at the rear end (wheel bearings?).
Hi,
I have done 7K kms now since the swap, daily driving and road tripping, no major issues. Still don't have a fan, but this engine is never overheating, even with this summer heat waves.
The biggest work that was done was insulating doors with material like "dynamat" and foam on doors panels in purpose of having a better stereo sound and insulation from outside noise.
I also had to drill bigger holes on the doors to make room for the new speakers, had to find a good method to drill correctly.
I don't have any photos of the insulation, but now stereo sounds a lo better! I have a project to install a flat sub under the trunk floor which will achieve a decent stereo system.
I just came back from a 1000km road trip in the massif central, south of France, did't took much pictures but :
Railroad bridge made by Gustave Eiffel (Eiffel tour).
So now, next step will be :
- Some maintenance (center shaft bearing, sway bar poly bushings)
- E-fan
- Oil/water exchanger, because for now original oil cooler doesn't let oil heat more than 70°C (158°F)
- Stainless exhaust
About stainless exhaust, I don't really know what size of tube to choose. The D24 NA original tube is 52mm, stock TDI is 60mm, and I have the choice between 60mm, 63.5mm (2.5"), 70mm or 76mm (3").
I'm hesitating between 63.5mm and 70mm, if anyone have an good advice?
I've been able to borrow a work space at some friends house, no somewhere with enough room for a car but I could put all my stuff in, that's cool.
I just thought that I never really took some photos to show how is the car, it's now done !
And its interior, after a bit of care :
I have the chance to have a good Volvo friend who has given to me all the missing/broken parts I had to replace everywhere, now it's in pretty good shape. Still have some work to do on the body, if one day I get the skills or money to do so.
No big new but I did some maintenance on the car last week. I was tired about replacing aftermarket sway bar links every 6 months so I went for poly bushings from strongflex. Hope it'll last long!
Replaced driveshaft center bearing/bushing either :
And in my quest of good sounding stereo for this car, I bought a sub. It's a Focal amplified sub, I hope it's good. I don't care about power, I just want an as clean as possible sound that can cover the 5 zyl diesel loudness!
I chose this one because it's flat and I had an idea in mind to make it invisible.
I don't know nothing about audio wave and such, I just hope this positioning is not too bad to make it sound good.
Continuation of the sub installation :
I took benefit of having the seat off to install a better floor carpet
Wired smoothly under the floor and all along the left of the body, I had to take a shortcut under the seat for the audio and remote cables, because for sure the cables they sell you are way to short for a Volvo wagon.
Like if nothing happened, nice!
Had a strange electrical mess when putting the battery back after that (https://turbobricks.com/index.php?threads/sudden-electrical-mess-1990-745.384680/), it was the glow plug relay that was dead.
I still have a driveshaft vibration at 100-110km/h, even with the new driveshaft rubber bushing and bearing. Don't know what to do with that... Is there is a way to know if the two halves of the driveshaft are well positioned together?
Today I did some fancy little things to the 740.
First I repaired the heated seats, they never worked since I had the car back in 2019. It had the switch light on when pushing the switch, but no 12v at the seat connectors. It was the switches themselves which were faulty, too dirty and crusty inside to let the current pass properly.
Just had to clean them well and I now have heated seats.
(Defroster switch here but they are the same).
Seats work fine but I was wondering how to have adjustable heat? https://turbobricks.com/index.php?threads/adjustable-heated-seats.384934/
Then I had a mod in mind I wanted to do, kind of a psychopath consideration but when I sleep in the car, I'm disturbed by the clock noise that sounds like a old normandy clock.
So usually I just unplug fuse n°5, but it's also related to interior lights and radio, which is annoying if you want light, or listen to something ahah.
I added a little switch to be able to quickly disconnect the clock without shutting off lights and radio.
So if someone wonder, you just have to connect the green/red cable from connector B on the cluster to a on/off switch :
Switch integrated to the dash next to the defroster switch :
Finally I played with some color permanent markers to make the additional oil temp gauge light the same color as the cluster lights
